1 Leave the DevTerm some period, and the screen is black out.
2 Wait some period, for example 1 hour.
3 Then wake up the screen, there some “ghost” pattern on the screen. The border of the screen is much brighter then center.
It seems the ghost pattern and bright border will fade out after dozens of minutes.
Does anyone have this problem? How can I avoid this annoying effects?
When I upgrading the Raspbian, I try to wake up the DevTerm, the screen is dead, displaying several colorful horizonal banners, this keep displayed until the upgrading is finished. The CPU tempreture is about more than 60°C。
After I reboot the system by remote ssh, the screen is ok, but the ghost image of horizonal banners last for a quit long period.
I cannot repeat the process, just try to take these photos, the border seems brighter than center:
I just built it now, and I have the same issue. To me, the screen is defective - but considering this is not a big company’s product, I don’t know if clockwork will exchange the screen. It’s too bad that the quality seems a bit less than I expected.
I did a few things today, and looking at the screen right before I shut it down just now – it seems ok. I did:
enabled sshd and VNC using raspi-config. Removed many s/w, changed background to grey color, and adjust brightness to 4. I VNC and ssh to it and ran/added/removed several things.
I noticed that the screen didn’t turn off it usually does when it’s not used for a while – I ignored this thinking it may be the VNC or ssh. Now I think something may have been changed.
Something else I noticed - in raspi-config, fan is not enabled. Nothing to do with the screen, but I wonder if this is how it should be.
I have the same issue as @philosiraptor and @hengying (the same look).
Also, I found that my uConsole has two horizontal lines of dead pixels at the lower half of the monitor. Should I be worried about it (a combination of back lumination issue + ribbon cable issue)?
