I recently got a ClockWork PI uconsole but my screen isn’t turning on can someone suggest some fixes for me please
What core are you using, CM4? EMMC or SD card? What image did you flash?
provide marcophotos of screen connector and FPC plugged in, it’s common that people not fully plug them
I’m using a sd card flashed with the is image
Good heavens. Do we need to be drip-fed the details to help you better? Are you from the CIA? MI6? FSB?
- What core are you using: (CM4, A-06, R-01)
- What OS/version are you using: (Debian/Clockwork, Debian/Community, postmarketOS, Arch Linux ARM, Ubuntu, Retropie, Kali)
- Have you checked if all the components are mounted/connected properly?
- What power source do you use? Is it sufficient to keep the device powered?
- When you power up the device, does a green LED stay on?
- How long did you wait for the screen to light up?
I’m fairly new to this stuff, I am a student in university but I will definitely look up these stuff you mentioned thank you for the advice
I will look into the connections thank you
If you have any questions don’t hesitate and send me a DM I’m also not new to this Linux stuff but I don’t mind lending a hand.
actually that’s harmful behaviour. Forum’s intention in general is to be somewhat searchable database of cases and knowledge, it’s noble that you’ll help one of users, but consider hundreds of visitors with same problem where solution lies outside of public view.
