Will there be the possibility to use the GPIO for serial GPSD input to have an accurate clock? There is a 40 pin GPIO located at the top of the board near the external module.
uConsole will be used for digital faint signal communications in the field. I need an accurate clock based on GPS with 1PPS signals → GPSD → Chrony → System clock. RTC would be nice, but not a must have
There are some amazing inexpensive GPS modules ( e.g. the GT-U7 is one that puts out PPS ) that are very tinker friendly. This is a fantastic feature request, if it isn’t already supported ( I’ve personally not looked into the 3.14 board schematics that deep ) and would love to hear "oh just use pins x,y,z. - if someone has looked .
This is the kit GPS I’m using with a Pi3B+ & Pi OS as a LAN time server: GPS receiver kit QLG2 with a clock display and enclosed in the case [Clock kit]. Using GPIO pins UART TX/RX, 5v, GND & pin 7 (4) for PPS. Direct serial is preferred for accuracy. With a bit of tuning, I’m seeing sub micro-second jitter. Current system time is 94 nano seconds fast of NTP time.
Have a USB-A BU-353S4 GPS puck w/o 1PPS that gives +/- 1 sec for field use, but would prefer a more accurate time. FT8/JS8 needs <2 sec variance, so I want to limit the variance I contribute giving great possible signal decoding
The uConsole GPIO is 40 pins, so I wonder if it is following the standard Pi-3 & 4 GPIO pin layout? Would think so since PiOS is included as an usable OS.
Thinking I could run an extension to the GPIO to the top of the case. Then design the GPS kit with display case with a plug-in to the now external accessed GPIO. It would nest into the top of the uConsole with the display above the main display.
Cleaner option would be to internally mount the GPS board with an external SMA antenna connector at the top. Wouldn’t have a GPS/time dedicated display, but use GPSMon to get the information
