Make a file shutdown.sh I have the file in ~/documents/ with the following
#!/bin/bash
shutdown now
Make shutdown.sh executable.
Then in the start menu select preferences, then main menu editor. On the right side select new item and point it to the script, name it, and select an icon if you want.
At the risk of exposing my lack of understanding, but how does one escape qsleep.sh once initiated? I did not want to replace the shutdown command so I tried just running qsleep.sh from the cli and was then unable to wake up the system.
The script works by cycle execute -> sleep - execute -> wake, so you need to find any way (like mapping any button/combo) to execute qsleep.sh, and it will sleep and wake up.
Don’t touch lxde-pi-shutdown-helper and your logout menu should still be functional.
For labwc, the instructions will be different. I have not upgraded yet so I have not looked into it, but according to documentation, they mentioned creating a file at ~/.config/labwc/rc.xml and then adding a <keybind> entry to it like so:
If you would like to map to something other than power key, running this in a terminal will tell you what code to use with Wayfire so it’s very straightforward:
My pondering on this while I await my uConsole arrival to experiment on is… is there a way to map a long press = shutdown menu, short press = enter sleep? I suspect it will have to be done in the script that is called in response to the power button press as I am assuming there are not different software events generated for short vs long press, noting there is of course the firmware response to a very long press!
So I guess I figured out how to map Power button in labwc, too. Just did the upgrade this morning.
Edit ~/.config/labwc/rc.xml and make sure the content is something like…:
<?xml version='1.0' encoding='UTF-8'?>
<labwc_config>
<keyboard>
...other key bindings may exist for say the volume/brightness OSD
<keybind key="XF86_PowerOff">
<action name="Execute" command="~/.config/qsleep.sh" />
</keybind>
</keyboard>
</labwc_config>
So no need to replace lxde-pi-shutdown-helper on labwc. This will bind the power button directly to qsleep.sh.
Also I added one small thing to qsleep.sh script:
# Stop all current running processes except for vital ones
# any other process that needs to be whitelisted can be put in this list
ps -U $USER | egrep -v "systemd|pipewire|wireplumber|wayfire|labwc|ssh|qsleep" | awk '{print $1}' | while read pid
do
kill -STOP $pid
done
# And then add this to wakeup block
kill -CONT -1
The above modification will allow any currently running process like say… a video, music, some game, an emulator, etc… to pause execution until qsleep.sh is executed again. Thus it makes qsleep.sh basically indistinguishable from real sleep to me since it does pause a video I’m looking at and resumes right away. But be careful with turning off display/GPU since that may cause some processes to crash upon resume.
Didn’t seem to improve “sleep” time by much but it does mean I can pause a running game and pick up right where I left off. Also has the added benefit of basically locking the current foreground process so keyboard/mouse inputs won’t do much.
Here you go. I have tested this extensively the past day or so (while playing games/emulators/music/Youtube, etc…) to make sure. It includes all of the above and I simplified some extra steps since we can make some assumptions:
#!/bin/bash
# sudo apt install cpulimit sysstat wlr-randr procps
# Add any process that needs to run in background during "sleep"
EXCLUDED_PROCS="systemd|pipewire|wireplumber|wayfire|labwc|ssh|qsleep"
# Governor to use after waking up
CPU_GOVERNOR="performance" # make sure this is set on startup elsewhere
if [ "$(cat /sys/class/drm/card1-DSI-1/enabled)" = "enabled" ]
# Display being off assumes device is sleeping
then
# Put CPU into powersave
echo "powersave" | sudo tee /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor
# Turn off display
wlr-randr --output DSI-1 --off
ps -U $USER | egrep -v $EXCLUDED_PROCS | awk '{print $1}' | while read pid
do
kill -STOP $pid
done
# Put all CPU-heavy processes to sleep, progressively re-checking every 60 seconds
nohup bash -c '
while true;
do
for pid in $(pidstat 1 1 | grep "^Average:" | awk "BEGIN {FS=\"[[:space:]]+\"} \$8 > 5 {print \$3}");
do
cpulimit -z -b -l 1 --pid=$pid;
done;
exec -a qsleep_bg sleep 60;
done' > /dev/null 2>&1 &
disown
# Otherwise display being on means device needs to be put to sleep
else
# Wake up CPU first to make process more responsive
echo $CPU_GOVERNOR | sudo tee /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor
# Turn on display and apply rotation (needed by Wayfire)
wlr-randr --output DSI-1 --on --transform 270
# Resume all stopped processes
kill -CONT -1
# Clean up previous scripts
killall pidstat
killall cpulimit
pkill -f qsleep_bg
killall qsleep.sh
fi
exit 1
This is usable either with wayfire or labwc. I would recommend wayfire if your workflow involves fullscreen applications, as the current version of labwc shipped with Bookworm does not seem to work well with fullscreen applications. I think we will see an improvement once we upgrade labwc to latest version, which does support fullscreen applications properly.
To use with wayfire, edit ~/.config/wayfire.ini and add the following under [command] block:
I put my qsleep.sh script under ~/.config but it doesn’t have to be there specifically.
To use with labwc, edit ~/.config/labwc/rc.xml and add the <keybind> block below. Please note that you may want to keep to a similar structure if your file is empty:
<labwc_config>
<keyboard>
</keybind>
</keyboard>
</labwc_config>
Both of the above configurations can exist at the same time and you can freely switch between wayfire and labwc easily using raspi-config, so just pick whichever one fits your needs.
Thanks for this! I was thinking about stopping, but never got to create a comprehensive list of apps that better be stopped vs. throttle’d, and I got particularly stuck at having gmail open and another tab playing youtube and wanting to stop youtube but not gmail
Otherwise, we should maintain a list of essential apps
Long press will be tricky. As far as I understand, current pipeline does not support separation between power button keyup and down. Also, if we want to retain the smartphoney-feel, we need to react to keydown, and then cancel and invoke power menu if keyup was delayed.
This had crossed my mind but TBH I don’t think my smartphone reacts to power button key down to invoke sleep state. The separation between short and long press feels to be very short, maybe 250ms to a max 500ms. It is so short it could be making me feel it is reacting to key down while in truth reacting to key up to invoke sleep!. It certainly doesn’t start to sleep between pressing the power key and the shutdown menu appearing. They could all be different of course!
When I get my uConsole I will have a play and see if I can get something functioning that tests if the power button key down is still active/down, if that is a possibility?. If after a window, let’s say 250ms but a configurable parameter would be best here, the power button key is still down it brings up the shutdown menu, else sleeps.
I was thinking to test multiple times for absence of power button key up within the window to make the reaction feel even more natural/snappy and like a reaction to power button key up.
Might I ask if there is a smooth way of mapping the power button in X.org/lxde? I tried replacing “Logout=lxde-pi-shutdown-helper” with “Logout=qsleep.sh” but pressing PWR still brought up the shutdown helper.
We need to check if cgroups are usable on shipped kernels. Because if they are, none of cpulimit* are required, and having the modern kernel to limit process will be significantly smoother and use even less energy than a userspace app. Otherwise, there is really nothing to fix or maintain in cpulimit as it is using a UNIX process sleep (SIGSTOP) method from 1970’s.
As a newbie to RPI and Linux, I’ve given it a few tries, but there have been some difficulties for me.
I’m using the Bookworm lite image from @Rex (thanks again!) and I was able to create a script file, but I don’t know how to map the power button to the button for the run and stop sleep script in Xfce4 circumstances. I’ve googled it and done some tries to find the way of mapping, but it’s a little hard for me, so I’d like to get some advice from our awesome member in this forum. Also, is there an organized version of the script? If so, I’d like to get it. ^^
