So I was watching Geerling
https://x.com/geerlingguy/status/1861681366737326269
Is the 5 gonna be a drop in replacement for the in the uConsole?
Yeah, that was my worry too. The Raspberry Pi 4:
Idle temperature: around 40-50°C (104-122°F)
Load temperature: around 60-70°C (140-158°F)
But the first few articles I’ve read said the 5 is about the same, and under typical loads would run even cooler than a similarly loaded Raspberry Pi 4.
So, there is hope heat will be drawn away by the case through chunk of heat conducting “tape”.
if and when someone gets a 5 that they can use with their uConsole if you will test for me I will make sure Void runs correctly with it
I expect CM5 to be cooler and faster than CM4 due to just being a generation or two ahead in node process. Basically, an undervolted/underclocked version would certainly run cooler even under full load, and still be overwhelmingly faster. A stock clocked version would throttle if pushed to limit without proper cooling, as many intel CPUs in fanless design do (like, 10 seconds burst then throttle down).
I wouldn’t use my mobile device as any kind battery powered mining rig or an LLM training infrastructure anyways, so I’d overclock the CM5 inside uConsole and enjoy.
