This module fit in uConsole Kit RPI-CM4 Lite
does this module fit uConsole Kit RPI-CM4 Lite
yes but you will need a separate io board to flash the emmc as the uconsole doesn’t have the ability to. you can’t use a emmc model and the sd card slot at the same time. you should get a lite cm4 so you’ll be able to use a sd card for the os.
