TwisterOS 6.12.y for the uConsole and DevTerm
you realize that CM5 is an ARM and most win games are not ARM, don’t you?
Winlator is an Android application that runs box86 and box64 with wine to emulate windows applications. All 3 of those programs are already installed on TwisterOS, so it’s already setup to run windows applications. YMMV on what windows apps will run though.
I’m getting an error trying to unpack ClockworkPi-Bookworm 6.12.30.img.xz. I’ve tried 7-Zip and ZIP Extractor. Both report a CRC error in the same place in the file.
You don’t need to decompress the image to flash it, but it does sound like yours might be corrupted. Have you tried to download again? Or just try and flash it with raspberry pi imager or etcher.
Peazip works better on these.
I learn something new every day! I didn’t know thar RPi Imager would unpack an image file. I thought it could only work with the .img file directly.
Thanks for the new (to me) knowledge! My $5.00 / month is well spent.
I really like this system, it saved me a lot of configuration and beautification work !!!
I set the maximum charging power to 2.5A, but the query is still 2.1, is it my operation problem? How can I increase the charging power?
The power management chips Max charge rate is 2.2.
Yup good old twister that can look like other ose’s
Had the same issue on your bookworm and had to use way land (BTW) or by the way.
UPDATE IN OP!
