Then you can stick back in your 512gb card and start setting stuff up. Enjoy, if you have any more problems feel free to give me a shout.
Is there a way to autohide the bottom task bar to get more space.
I just ordered a set of the Samsung 35E batteries.
I found this thread but trying does make it hide but it doesnāt reappear.
https://forums.raspberrypi.com/viewtopic.php?t=369556
Iāll check it out some more and see if I can find a solution.
Do we need to use command line to enable and disable 4g. I will test it out soon with UK EE. My batteries have charged now to 100% lets see how they hold out as they were dead on arival when shipped to me this is my first time charging them.
I donāt have a 4G card so Iām not 100% sure on how to set it up, but the script works by uconsole-4g enable or uconsole-4g disable
I want to find a way to boost wifi and 4g signal. There must be some mods fitting a better antenna.
you can move existing one outside of metal case by adding block of something
Solid cover, antenna mod - uConsole by Kirouh - Thingiverse -
Reddit - The heart of the internet
uConsole micro antenna 0.2 mount by m3x | Download free STL model | Printables.com
Is anyone able to 3d print this in black x2 will pay for it thanks. Please pm me.
I have ordered the same antenna as in that mount adapter.
Does the CM5 have superspeed 5Gbit USB 3.x? Will there be an updated carrier board available to apply Super Speed USB devices to be connected? I would really like to be able to connect 5Gbit devices.
Hi Rex i tried the bigger card after i done this but it rebooted 3 times then crashed blank screen twister on cm5 uconsole. May be the the commands did not stick that i wrote to allow bigger cards?
Changing the EEPROM will stick with the device as itās written to the firmware of the CM.
Did you apply any custom settings when flashing like with RPi imager?
I didnt it was a fresh install just built the uconsole i will try again.
I mean when flashing the image some software you can apply WiFi and a user/pass when flashing. If you apply customs settings when flashing the image will fail.
No settings applied i unzipped the files and burned image using syste.32 imager i mean i saw the twister boot logo 3 times but then crash blank screen 512gb samsung card.
donāt decompress the image and try rpi imager or usbimager to flash the .xz to see if that changes anything
I will try that and see what happens.
one of my friend tried building on it too, and honestly, itās been a pretty frustrating experience i helped him out. The process feels way more complicated than it should be, and the lack of clear instructions doesnāt help. Hoping for a cleaner setup soon. We finally managed by watching a youtube video some nobel saint might have posted it for noobs like us lol haha
Do you mind sharing what worked for you to use a bigger sd card?
