UConsole Ethernet
Hi
Is there a way to plug an Ethernet cable into the UConsole?
Would a USB-C to Ethernet adapter work?
I’ve not received mine yet and just want to prepare myself before it arrives.
Thank you.
Stock there’s only USB-A, the USB-C is power in only. There are expansion cards available that add USB-C but only at USB 2.0 speeds.
So pd adapter won’t work.
So if I used this adapter…
It would run at 100Mbps?
@Shemida_Fernandes a pd charger will work but will only pull 2.2A @ 5V
@Kyzer 100 or it might connect at 1000 but only actually do 480, but it will work.
You might be interested in this extension board uEther.
It adds a 100 Mbs Ethernet port + USB type C (2.0)
This is exactly what I’m looking for!!!
Thank you!!!
