[UConsole]Fix Login Screen(sddm) Rotation after boot
After you set kde-plasma as your main DE do the next:
  1. add next line
xrandr --output DSI-1 --rotate right
to the file
/usr/share/sddm/scripts/Xsetup
  1. Add next lines
[X11]
DisplayCommand=/usr/share/sddm/scripts/Xsetup
to the file
/var/lib/sddm/state.conf
reboot.
after i got correct rotation right after boot. maybe it will help
To solve the orientation of KDE at startup, I use another solution: I boot directly on the desktop, then a script immediately locks the screen, which is always oriented correctly, even on an external screen! And I can connect normally.
and does it keep rotated after reboot? because when you set it via desktop it works, of course, but resets after reboot
Yes it is! This setting remains after reboot, because it’s a Desktop Environment’s setting, not a SDDM or Lightdm tweak.
(Sorry for English, I reply fast but trashy :sweat_smile:)
This doesn’t seem to work on Plasma 6
Edit: Never mind, i’m an idiot
In case someone else comes across this in the future, my uConsole’s display was DSI-2. So sometimes it is different.
Run xrandr in the terminal. If xrandr shows XWAYLAND0 as the display device, it means that your DE is using Wayland. That display device is not the one you want. You’ll kind of have to “guess”. Try DSI-1. If that doesn’t work, try DSI-2.
I had to go in and just change the orientation for the time being. Going to consider all these solutions. It just randomly did that after some time of not using it.
