Because I couldn’t find a working audiobook player, I vibe-coded one. ![]()
It’s not perfect but has a nice cover overview, saves the progress for every book, and the Pi CM5 runs at 1500 MHz.
Other than the defaults (which assume the user is named pi; the SystemD service won’t work and might mess with the system otherwise), what about this is specific to the uConsole?
Your mentioning of the CM5 running at 1500MHz with regards to an audio player is at best an irrelevant statement and at worst an extremely alarming mix of topics in implying you are tweaking my processor configuration if I run this code.
Thanks for your Answer.
I don’t manipulate your CPU clockspeed. I mentioned the CPU speed because 1500mhz is idle speed. Because of battery life it’s important not to stress the CPU with a simple Audio player.
