Speakers stopped working
The built in speakers stopped working. The headphone jack does work.
I have tried
  • double checking alsamixer to make sure nothing is muted
  • the “sudo apt reinstall DevTerm-patch” fix from a similar post
What are my next steps?
I have the CM4 module.
What os and kernel?
Do a
systemctl enable devterm-audio-patch
And see if that works.
If that does work I’ve worked up at new audio patch that uses the newer way to address the gpio
That did not work.
Kernel is 5.10.17-v8+
So you tried
sudo apt reinstall devterm-audio-patch
now in /usr/local/bin/ the file called audio_3.5_patch.py back it up and replace it with this.
then run the following again
let me know if that worked
Ive found the audio settings in raspi-config helps with the issuetoo
I modified the file with no success.
I’m still only getting headphone as the only audio choice
do the following to see if we can force them to work
pinctrl set 11 op dh
then and post the output and tell me if it worked.
pinctrl 11,10
have audio playing while you try this.
I’m getting pinctrl:command not found.
I’m relatively new at Linux, so excuse my ignorance. I did also try the command with sudo
replace the original file you backed up. give me the out put of this.
raspi-gpio get 10,11
then do
raspi-gpio set 11 op dh
then give me the output of again.
gives
GPIO 10: level=0 fsel=0 func=INPUT pull=NONE
GPIO 11: level=0 fsel=0 func=INPUT pull=DOWN
and
FIXED THE AUDIO and gave
GPIO 11: level=1 fsel=1 func=OUTPUT pull=DOWN
Thank you for your help
I suspect it’s not fixed fixed. A reboot will reset it. We got to figure out why it’s not detecting pin 10 being low. Or why pin 11 was set to input.
Sudo apt reinstall devterm-audio-patch
And reboot for me and reboot for me then run and post the output
Ran the two commands, rebooted, as requested
Something is resetting pin 11 to input or the patch isn’t working. You have python installed still?
The last few days of my free time I’ve been working a driver to change the pins for the audio to not have to worry about userland.
Yes Python is installed
have you installed or done anything that might change the gpio pins?
you could compile pinctrl and see it that patch will work. besides that im not sure what could be not letting the script run or changing the gpio pins. as a temp solution you can just use.
I used GitHub - WiringPi/WiringPi: The arguably fastest GPIO Library for the Raspberry Pi to get Pico-8 to run.
You’ll have to reinstall clockworks wiringpi, not sure if the way you got pico 8 setup will quit working or not. But this is the following package you’ll need to reinstall.
devterm-wiringpi-cm4-cpi
If you do let us know if that worked
I did reinstall it, it did not fix the sound issue.
I did get a fresh image on a second SD card, and was able to install and run Pico-8 without issue and the sound is working fine. So I’m equally happy to walk away from the mess that I made as I am to help you sort out what happend so that it doesn’t happen anyone else.
