uConsole Mod Megathread
Meet the almighty colorful one.
I do wish I’d ordered this front cover when I got the trackpad keyboard, but that day I decided boring black was the right choice.
Same :sweat_smile: Figured it would be “too flashy” but still end up doing colored parts haha
do you have a linkt to stl files for those antenna covers? Those are awesome
I don’t a friend of mine done them for me.
internal usb hub plus bluethoth amd pendrivelike second internal unit of ssd its not too fast but enouth for bacup music and movies, internal nmve and hackergadget expansion and wifi 1200 bluetooth never work proplely , batteries its real 7000 and 6300 are not perfect but very close i dont know how many hours yet can archieve i need recalibrate my battery sensor
If Bluetooth isn’t working, then this WiFi 1200 module doesn’t make much sense, does it? I’m currently using the CM5’s Wi-Fi and Bluetooth, and I tried adding another MT7921AUN module, but Bluetooth also failed—I don’t know why.
i use first external its ub500 tp link mudule. i buy one 6 x brand but i dont tested and the tp link work even inside de uconsole , blueman can be a pain in the ass i use codex when some chinese bluetooth gadgets cant pairing ussualy its password asking wen its a mouse or xaomi headphes, i dont use cli bluetooth comands but codex cl usualy modify the trust sistem, may i make a repo only for these problems its seem a very comon in linux need changes de trust sistem for pairing some devices others like my sony headphones or logi mx mouse work just fine. the wifi 1200 combo never work i think its a desing?/electric? problem maeby be cause its show but when pairing reboot wifi and bluetooth but when i disable Bluetooth the wifi its stable and better wifi range ! the wifi works just fine!
I finally installed the 21700 battery board.
I modified a battery holder designed by someone else and shared on Makerworld, added a kill switch, and made it so I can easily remove the battery with just one finger.
It also matches my custom-made back panel very well.
On the WiFi 1200 combo issue: if WiFi becomes stable the moment Bluetooth is disabled, that smells more like 2.4 GHz coexistence or power/EMI on the internal USB hub than a dead card. Lanthar seeing the same with an MT7921AUN supports that. Try the combo on an external powered hub, and check whether Bluetooth needs a separate antenna or a board-specific firmware file. Not certain, but worth testing before writing off the module.
yes i have the same problem be cause of these i put other usb bluethoot inside of my uconsole
