uConsole + rpi cm5 one key on the keyboard not working
Hi, I’m new here and not very familiar with the topic, but one key on my keyboard (q) doesn’t work. Is this a known issue? I wrote a script that displays the codes of pressed keys, but when I press “q” nothing comes up. It doesn’t seem to be a hardware problem, because the keyboard module itself communicates correctly. Have there been any issues with the firmware for this component?
Additionally, I have the latest Ubuntu from Rex installed (ClockworkPi-Ubuntu-24.04-6.12.45).
that’s not okay.
  1. check with xev (x11) or wev (wayland)
  2. try to reassemble front side and reconnect keyboard
  3. write email to alex@clockworkpi.com and he should send you a replacement board
I’ve checked 1 and 2, but the problem is still there. I’ll check if the state changes on the controller’s input lines when pressed, but I need to get a multimeter first…
you will need to take it apart and check the dome of metal under the Q key that it is sitting over the contact on the board, when i got mine one key was ever so slightly to one side so was not making great contact, it just took me two seconds to move it over a bit under the tape keeping it in place.
Unfortunately, that’s not the cause; for me, all the buttons look fine. These contacts are soldered very well, and without a meter with good, sharp probes, I can’t check whether the button itself is faulty.
ah ok worth mentioning just in case a easy fix.
Hi,
Back to the topic: I’ve checked the button mounted on the PCB and it works correctly. Unfortunately, the controller still doesn’t react when it’s pressed.
This is the M41 button. The row4 and col1 lines are functioning properly because the other buttons on these lines and columns work fine.
Any ideas?
have you tried removing the pcb and clean the pogo pins? when doing so make sure batteries/battery pack is disconnected.
If the connection were not working, it would not only affect a specific key.
request a replacement board
I have just got this problem now keys D5XT have all stopped working anyone have any ideas?
are the non-working buttons on the same line of the microcontroller?
