uConsole won't boot after long time off
I haven’t used my uConsole for several months and wanted to try something on it now. I flashed a new SD card with the official system image, plugged the device into USB-C power and turned on, the screen backlight went on but nothing else. After a few minutes the device seems to restart itself and it’s stuck in this state.
Also, the yellow charge indicator LED doesn’t turn on for some reason.
It used to run just fine last time I used it.
Any ideas?
Make sure the charger is putting out at least 2.5A, the batteries might be completely dead. Make sure the CM is fully seated in the adapter board, if you opened the back it might have pulled out of socket.
After you get it working try a more updated distro for better support and more up to date software.
