uConsole Won’t Turn On After Soft Reset – Battery Removal Required
Hi everyone,
I’m experiencing a strange issue with my uConsole running Bookworm 6.12. After performing a soft reset, the device restarts but the screen stays off, and I’m unable to power it back on unless I remove and reinsert the batteries. Has anyone else encountered this problem?
are you using a cm4 or cm5?
Hi,
I am using a CM5, I forgot to specify this. Thanks for asking.
Update:
After adding the missing parameters, the issue is now resolved. The uConsole restarts and powers on as expected. Thanks to everyone for your help!
[all]
BOOT_UART=1
Switch off PMIC outputs on HALT
POWER_OFF_ON_HALT=1
Try boot on SDCard repeatly
BOOT_ORDER=0xf1
SD_BOOT_MAX_RETRIES=2
Slow down SDCard SDR Mode on bootloader
SD_QUIRKS=1
