My uConsole won’t charge when USB-C cable is plugged in. When I click on the battery icon in the top right corner, it shows “Charging 0%”
dmesg | grep -I battery
[ 7.004688] axp20x-battery-power-supply axp20x-battery-power-supply: DMA mask not set
[ 7.005882] axp20x-battery-power-supply axp20x-battery-power-supply: couldn’t set constant charge current from DT: fallback to minimum value
Do I need to buy other 18650 battery?
Freshly built? Maybe look at the connection between battery board and the other board. I had the same problem and discovered that I did not connect the battery board correctly.
yes this fixed it. Mine is super flumsy… it’s just luck it didn’t push itself out again (the pinheaders are bent)… but I could now use it with super old batteries (will exchange soon). This is not a good design / breaks easily! Be careful everyone!
Thanks!
