That is an assumption, but the power section of the DevTerm seems to work just fine so unless you can’t get parts you stay with it. In large volume manufacturing, you redesign it to save money. They just aren’t making enough units to justify the cost of redesign.
True, though in the present day availability problems are massive and parts cost fluctuates wildly. It wouldn’t surprise me if there were some revisions due to parts being hard to get or their cost quadrupling.
though i doubt the AXP228 will change as it seems to meet their spec of 2.2A USB charging at insanely high efficiency levels (claimed 98%) and seems readily available.
I just need to see if there’s anything i need to change to make it charge Li-Po instead.
I intend to make heavy modifications to the Uconsole. Im honestly buying it for the keyboard and track ball more than anything and the fact that i can run a CM4 core which brings me into ‘standard hardware land’ so I don’t need to fight with proprietary drivers out the ass (looking at you Mali).
but the first thing to be changed in the battery(s) for sure.
Sounds like fun to make a bunch of changes. I might get around to doing that at some point. I also have a Beepberry on order and have redesigned the PCB already. I will likely have mine this week and will have parts of it running shortly. I agree on the driver issues, software can soak up massive amounts of time.
I have the TI Rocket board - never did anything with it - it was like $15 when I purchased it…
If you prefer the Arduino environment, many of the MSP430 boards work with Energia. It works just like the Arduino but it is for the MSP430 series.
This is a great topic - can’t contribute, but I learned a lot. Thanks to everyone who weighed in.
You kind of sound like an AI dude.
Hi,
Can you tell the header partnumber?
CF200-00204-1G1 this part from mainboard schematic is not good. I cant find any part by this number.
From TEconnecrivity I found with 3pins this part with 2mm pitch. 1612901-1
Thanks.
Hi,
You can solder 2x these breakout boards:
VOUT+ to Voltage.
VOUT- to Ground.
(to 2x of these connectors)
BAT+ to bat power.
BAT- to bat ground.
And these batteries, x2 (you don’t need the battery board, just the small ones I shown!):
I am sure all can easily fit inside.
Im looking to try to replace the 2x18650’s with just 1x10,000mah Battery i it will fit. Thoughts?
[Edited]
Try this
You can search by size and by capacity.
Take the right measures and go for the max ammount of mah (3.7V).
But, in my opinion, 2x5000mah will be easier to find. ![]()
This is even larger then the batery I have. The size of the 10,000mAh I have is 100mm x 59.3mm x 17mm But even with that plugged in the uconsole doesnt like it wont power up it starts to come up the back light comes on then it powers off. So I reverted back to the 2 x 18650’s and at least it powers up all the way and works. Perhaps there is more to the power path then what i could decipher and because im only using 1 battery it doesnt like it.. ???
Yeah I noticed, edited, sorry.
No worries thank you though..
