I guess this is more a question for the Clockwork guys. I’d like to know if we’re stuck with the default Raspbian that came with the DevTerm?
For instance, why (when using RPI-CM3) couldn’t we run anything that would run on the RPI 3 in the first place? And what would be the procedure to run another linux distribution (e.g. debian) ?
I would like to understand what are the eventual limitations to run other OSes than the default Raspbian on the DevTerm. I’ve tried to boot other images that I can run on a Raspberry Pi 3B+ but I cannot tell if they boot. The screen stays… silent.
Have you tried connecting an external display through hdmi?
The wide IPS screen on the DT probably won’t work until it’s configured on whatever OS you’re installing.
Some other things you will probably need to setup on your own with other OS’s:
I’d be very interested to see a textmode-only minimal OS image optimized for boot time. How fast could you get to a REPL from power-on? A second or two? If so, I could see the DevTerm having some real utility as a desk calculator.
Are the kernel patches described somewhere? If this device is to live up to its “An Open Source Portable Terminal for Every Dev.” tagline, they probably should?
