minimal gui program footprint. ie, no games or IDEs like the existing one
i3 window manager with compton compositor
Along with a bunch of other little stuff I didn’t keep good enough track of on my first pass. But what would be key to a STARTING image for you. ie, something you would use as a base for your own usecases?
probably a bit easier for most people to get started with openbox than i3 too, and I think it also supports compton, etc. I was going to include all the og drivers, or did you mean the fancy kernel driver?
I’m also hoping someone has a fix for the display offset on rpi3. I see a fix for one of the A modules, but that’s it so far.
I think I’ve found the file I would need to edit, and it seems like the values for the CM3 effectively match the ones for the A04. But I’d still need to learn the kernel build pipeline to get an updated copy =/
We’re up to bookworm! I just need to fix the first launch wizard =D
This is not the full version mentioned in comment one yet, it’s just an upgrade of the stock image with libreoffice and all the IDEs stripped out, but still a big jump!
Anyone here know how piwiz changes the default user in a Raspberry Pi OS installation?
I’ve got everything booting up correctly and even changing the pi user to the user name you specify, but it keeps booting into rpi-first-boot-wizard instead of the new username.
Working up an alternative first boot wouldn’t be terrible, but I’d rather get it working with upstream.
I’ve got a conversion of raspios bookworm that seems to be working fine for everything*. I’ve got the basics of script up on github, but it’s not exactly follow along/ready to be run just yet. Now that I’ve had a successful build I need to script it all up.
Here are the key points if you want to take a swing:
Add the clockworkpi repos
Distupgrade everything
Remove linux-image-rpi-v8:arm64
Remove linux-image-6.1.0-rpi8*
Copy the libwiringPi files to /usr/lib/
chroot_helper will help setup the chroot and get you into it
chroot_history.out.sh has the command run within the chroot
Everything in this case meaning everything that doesn’t rely on python2, so no fan control until that gets updated to python3
Ok, this can now just be run as a script. Download the package from github to a raspberrypi 3 already running a rasbian based OS. Grab a copy of the most recent 32bit Raspios and point makecm3devterm.sh at it. How long it takes depends on how much you put on the Pi.
~20 minutes if you download and decompress the .img on another computer first and don’t run it on the SD card
~35 minutes if you download it direct to the raspberry pi and don’t run it on the SD card
~45 minutes if you download it direct to the raspberry pi and run it on the SD card
Thanks for making this script. I’ve used on some recent releases. New updates overwrite the configuration though. When i do an apt upgrade the screen on the devterm does not show the desktop any more. Do you know what package i should hold back in an upgrade to avoid this?
Can this be run on a Devterm cm3 that is running the Clockwork image?
The screen going black worries me, all of Rex’s images are the same for me and personally I’d prefer Parrot, but beggars can’t be choosers when it comes to Devterm.
