Like compatible with picocalc, most ram, best cpu, etc.
also has to be available with pre soldered header pins, and easily available.
It’s simple enough to work with if you are used to Linux cli & know some Bash - also the hardware mod pictured is only necessary if you want sound working - which for the type of device the PicoCalc is I would argue is a luxury not a necessity…
