I’m using a debug probe to download my code, VS Code with a terminal emulator monitoring for output. I’ve tried every channel it offered, although the actual USB C cable connected to the PicoCalc (NOT the micro USB connected to the debug probe) is the one I’d expect output on.
I have this boilerplate at the top of main
stdio_init_all();
uart_init(uart0, 115200);
uart_set_format(uart0, 8, 1, UART_PARITY_NONE); // 8-N-1
uart_set_fifo_enabled(uart0, false);
and I have this in my CMakeLists.txt
pico_enable_stdio_uart(my program 0)
pico_enable_stdio_usb(my program 1)
If I try to disable stdio_usb in particular I get weird compile and/or link errors.
What am I missing?
Thanks,
-Dave
Of course I figured it out right after I posted. Only code I needed was stdio_init_all, not the uart init stuff, and I had to set pico_enable_stdio_uart to 1 as well.
If I disable stdio_usb, I get weird include errors like
fatal error: hardware/flash.h: No such file or directory
4 | #include <hardware/flash.h>
I used some sort of VS code plugin to bootstrap my pico CMakeLists.txt since CMake syntax is utterly cryptic to me and I just want it to work.
I assume the issue above is because enabling stdio_usb has some side effects on the standard include paths or some such. I can’t even figure out how to set CFLAGS etc with CMake (I have used Make on and off since the 80’s, and have a lot of experience with build systems in general, having written a few of my own, but I just haven’t figured out CMake yet and its documentation isn’t… the best)
I feel your pain.
Read 2.4. Directory Structure in the Raspberry Pi Pico-series C/C++ SDK documentation.
I wish I found this sooner myself. I too “get” make, but I am slowly learning this dang-fangled CMake.
Thanks.
Just needed to explicitly add hardware_flash and hardware_gpio to my target_link_libraries command.
-Dave
