Where can I find information on the PicoCalc SD card slot?
I’m making an OS for the PicoCalc, and I am currently working on setting up a FAT32 file system for it, but the issue is that I can’t learn how an SD card slot works, and particularly any information about the PicoCalc’s SD card slot. If you have any information or links, please help!
I would assume its like any other such slot. What exactly would you like to find out?
SD cards on microcontrollers work via SPI
and I found this on the first page of google
I have an SPI SDHC (not traditional SD card) driver for zeptoforth at zeptoforth/src/common/forth/sdcard.fs at master · tabemann/zeptoforth · GitHub. Yes, it’s in Forth, but it should help inform you as to what is involved with an SPI SDHC driver.
How to initialize it using SPI.
I’d say look at the source code of any of the other PicoCalc apps that have SD card access, but specifically GitHub - oyama/pico-vfs: Thin virtual file system for Raspberry Pi Pico which you can also just use directly instead of implementing the hardware access and filesystem support yourself.
