Hello I had saved resident evil 2 as a test to see if it would make a .srm so I could replace it with uploaders .srm with rocket launcher. What I find is that the save file after I make it can be found in both the re2 original and dual shock version so the .srm is not embedded in the bin file but it means it must be somewhere but I can’t find it?
They’re all located in a hidden directory. Have a look there. I’m assuming this is what you mean. Let me know if it’s not.
I’m also assuming you’re using the standalone pcsx reloaded and not the Retroarch core.
