I have tried to logon to my WiFi network using the nmcli command. I get a connection activation failed: (7) secrets were required, but not provided.
How do I connect to WiFi? Any help is appreciated. Thanks
I’ve found on the CM4 that it works if you use: sudo nmcli --ask dev wifi connect NETWORKNAME but will error out if the --ask is missing.
Running nmtui should also work.
Just got my R-01. I am having the same issue.
I just posted a new topic that works. Check out video by BlueMonkey 4n6 https://www.youtube.com/watch?v=c-9kRhvs3Mw.
