uConsole keeps asking for WiFi password
Sorry if this has been asked and answered before. I could not find an answer so I’m posting.
I recently decided to switch over to the Pi-Lite/XFCE image. I flashed it on a new SD card and booted up. My uConsole sees my wifi clearly, I have ok signal strength, however I can’t log on because it keeps asking me for my password. I even went and checked my router settings but I’m typing it correctly. Has anyone else had this problem and if so, how did you resolve it?
Does your router support WPA3 security? I had a similar problem with my uConsole trying to connect to wifi using WPA3 even though it doesn’t support it. I had to manually set WPA2 Personal in the uConsole’s network settings and then I was able to connect normally.
I fixed this problem by setting wifi parameters in config.
sudo raspi-config
