I addded a 4 port USB hub with the help of 3D printing and 1 180-degree connector.
The placement is nice! I have trouble understanding how you mounted it. It must be more convenient than on the side.
Circled is the 180-degree connector going into a 3d printed case on the back. I will eventually be installing a SDR in the case also
Ho I see! Your custom printed back add on is cool! Have you modified the metal shell?
Yes, one thing I found flawed was no access to the battery with the metal case on, so I cut out that area allowing me quick access
