AC1200 (MT7961) Bluetooth can't hear or pair with peripherals on uConsole CM5 + AIO v2
Setup: uConsole with CM5 (no onboard Wi-Fi/Bluetooth) and HackerGadgets AIO v2. AC1200 card (MediaTek MT7961/MT7921 family, USB 0e8d:7961) connected to the AIO v2 USB-C port via an OTG adapter, enumerating on USB 3 port 3-1. Debian 13 (trixie), kernel 7.0.0-38 / 7.1.4-v8+, labwc Wayland session. Wi-Fi works normally.
Symptoms: a Logitech MX Anywhere 2 on a Logitech USB receiver (Type-A port) drops off the bus repeatedly and moves jerkily. It worked fine after the AIO v2 current-limit resistor was changed to 4.3k, and still works on other machines. Bluetooth pairing fails with every device tried: MX Ergo, MX Anywhere 2 and an iPhone.
Logs: the receiver disconnects repeatedly from ports 1-1.2 and 1-1.4.1, sometimes after a dwc2 port reset (about nine drops in one session). The adapter connects to the iPhone and runs service discovery, but no pairing step starts. For the mice, btmon shows the adapter hears none of their advertisements, while it hears other nearby devices at -56 to -74 dBm.
Power: 5V input steady at 4.91V idle and about 4.83V under full CPU load. A combined Wi-Fi flood ping and Bluetooth scan held 4.91-4.92V. throttled=0x50000 is set but dates from power-on (early boot entries predate the clock being set). aiov2_ctl --watch showed a steady 7.3W from the charger during a pairing attempt. GPIO 23 (USB rail) is driven high. Earlier boot logged Bluetooth: hci0: Opcode 0x0c03 failed: -110 followed by a USB port reset; nothing similar since. The device binds to both btusb and mt7921u, and the Bluetooth firmware loads cleanly (build 2026-02-24).
Ruled out: stale pairing records, device class (0x6c0000 vs 0x6c0500 made no difference), bluetooth.service restart, power under load, firmware version, antenna connectors (checked physically).
Not tested: a separate USB Bluetooth adapter (none available).
Device changes made during testing (all reversible): Solaar was installed (apt install solaar) and udev rules reloaded. A libinput section was added to ~/.config/labwc/rc.xml to disable the built-in pointer (backup saved as rc.xml.bak-* in the same folder). bluetooth.service was restarted. The adapter’s device class was changed to 0x6c0500 and then restored to 0x6c0000.
Question: is the AC1200 Bluetooth expected to hear BLE advertisements and complete HID pairing on this board? Is there a known issue with the AIO v2 USB 3 port or the power budget for this card?
can you please make a photo of your antenna? is it inside of the case? can you try to pair without back panel?
i belive the bluethoot not work in any unit i never hear anyone can use, i finnaly adding a external bluethoot usb soon ill make internal adding some wires i hope some kind of fix but i belive its the dongle bad adversting / desing
bt headphones/gamepad work just fine on trixie@cm4
nice hear these, can show me your configuration, i use cm5 ma’ebe its not enouth power for stabilice both thanks
