AIO V2 — does Bluetooth actually work for anyone?
uConsole with CM4, HackerGadgets AIO V2 (WiFi/BT come from the AC1200 USB-C daughter card that plugs into it — same MediaTek MT7961 chip, shows up as 0e8d:7961). WiFi works great, but Bluetooth never held a connection for me — pairing would start and then drop, with HCI reset errors in dmesg.
Dug into it a bit and found the kernel driver ClockworkPi ships is missing a MediaTek entry that’s actually present in their own GitHub source. Rebuilt it and it got noticeably better — full pairing completed, which never happened before. But it’s still unstable: during longer use a BT timeout took down the WiFi on the same chip too.
Before I keep poking at it: is anyone else running the AIO V2 (with the AC1200 card) with Bluetooth working reliably? Or is this a known issue with this chip/board combo?
Odd question but have you connected the two antennas to the SMA connectors on the AC1200?
There are four SMA connectors, two for wifi and bluetooth.. as in two on each side
Source, I missed this myself :grin:
我连接其他(不是hg生产的)基于mt7921aun的usb wifi 蓝牙符合设备也遇到类似的问题
Bus 001 Device 009: ID 0e8d:7961 MediaTek Inc. Wireless_Devic
__ Port 2: Dev 9, If 2, Class=Wireless, Driver=btusb, 480M
|__ Port 2: Dev 9, If 0, Class=Wireless, Driver=btusb, 480M
|__ Port 2: Dev 9, If 3, Class=Vendor Specific Class, Driver=mt7921u, 480M
|__ Port 2: Dev 9, If 1, Class=Wireless, Driver=btusb, 480M
hci1: Type: Primary Bus: USB
BD Address: 00:00:00:00:00:00 ACL MTU: 0:0 SCO MTU: 0:0
DOWN INIT RUNNING
RX bytes:14875 acl:0 sco:0 events:2125 errors:0
TX bytes:547538 acl:0 sco:0 commands:2125 errors:0
Features: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Packet type: DM1 DH1 HV1
Link policy:
Link mode: PERIPHERAL ACCEPT
[ 354.206063] Bluetooth: hci1: Opcode 0x0c03 failed: -110
[ 354.590062] usb 1-1.4.2: reset high-speed USB device number 9 using dwc2
[ 354.698017] Bluetooth: hci1: HW/SW Version: 0x008a008a, Build Time: 20240219111427
[ 354.765952] mt7921u 1-1.4.2:1.3: HW/SW Version: 0x8a108a10, Build Time: 20240219110958a
[ 354.781432] mt7921u 1-1.4.2:1.3: WM Firmware Version: ____010000, Build Time: 20240219111038
[ 359.705951] Bluetooth: hci1: command 0xfd98 tx timeout
[ 359.705964] Bluetooth: hci1: Failed to apply iso setting (-110)
[ 359.705968] Bluetooth: hci1: Device setup in 4892029 usecs
[ 359.705971] Bluetooth: hci1: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
