Did anyone thinking of adding a wireless charger like magsafe to the back of the uconsole?I find this on Chinese Aliexpress(TaoBao).It can be sticked to the back of uconsole, and its max charging power is 18w. Though i have not received my uconsole ,I think it will be cool to add this.
Mine draws about 1.4 amps at 5 volts, sometimes almost 2 amps. After the batteries finish charging, I’m seeing 1 amp or less during work loads of 50% to 75% CPU with a CM4 8GBwireless, no emmc.
The description of the magnetic charging receiver says it can support 10w,That means it will work on the Uconsole.Thanks for telling me these information.
You are welcome, those values were from my USB PD charger and doesn’t change if I use USB A or USB C, same amps, always 5 volts.
I would wire that pad to the C socket power lines so that any input protection is still in circuit. It should work fine.
hey! did you ever get this running? i was considering a similar idea, but even just temporarily using a magsafe as a powerbank stuck to the back would be great. i just have a lot of that residual fear of magnets from back in the day, and the manual included a notice about keeping magnets away.
i know it’s largely a non-issue these days, but that notice renewed the fear of god in me, so i wanted to check if you had done this successfully.
hope all is well!
