It’s best to put the cm4 in the adapter board before putting them in the mainboard, it takes a bit of force and the sodimm slot can flex a bit so it’s harder to get it to fully snap in place along the entire connector if you try to install the cm4 into an installed adapter board
And for the wifi, the included sticker antenna works best when it’s not directly against the metal case
