Has anyone managed to get virtualbox running on this yet?
Tried a few ways but had no success yet.
I have a few old windows programs that need to run on XP or earlier that I use to connect to control systems and inverter drives on site. It would be great if I could do all that off the uConsole and not have to take my laptop everywhere.
Trying to follow all the discussion here… is it safe to get the CM5 at this point? is all the functionality working with the img posted on this thread?
I was running bookworm with, I believe was the 6.6 kernel (i didn’t take a pic before i ran the update so, I don’t know more specifically than that). I do know that I flashed my emmc with whatever was current in late December. I got it rotated correctly now, after the login. i used [quote=“Rex, post:54, topic:15847”] sudo apt install clockworkpi-kernel clockworkpi-cm-firmware
[/quote] for the kernel update. current kernel version according to unmae -r is 6.12.16-v8+
everything else seems to be working as it should. Thanks.
I got my uConsole with cm5 yesterday and everything went smoothly. The only issues I’m having is with the keyboard. When I press shift and @ all I get is “”” . I tried updating the keyboard firmware as shown in the GitHub but it’s giving me an error. Is firmware the issue or is it just a setting somewhere?
You have to run sudo raspi-config and select (6 Localization Options) then (L3 Keyboard) and set it to US keyboard. For some reason when you select it during account creation it doesn’t set.
That’s still a thing but separate from the OS. You’re flashing the microcontroller firmware that controls the keyboard. I recommend the QMK firmware from like 09222024 or something like that. From the 22 of September.
Loving the image, but hate having to take the battery out after every boot try :') seem to have a lot of issues getting the display to output properly. Any suggestions? Already did the above first-post modifications.
If the panel doesn’t display an image then just double tap the power button to shutdown. Or hit the power button once and hit the down arrow and hit enter to reboot.
Exact same issues here. Also I couldn’t update initramfs when using apt-get update/upgrade.
Sadly, since I use my uconsole for work, I had to take the CM5 out and revert back to the CM4 and my old 6.6 image.
The crashes and the multiple reboots don’t bother me so much, but when the power button goes dimly lit green, it won’t reboot or go turn off unless I take out the batteries. That’s not something I can repeat every other day.
Teething issues for sure though, I have faith Rex and others will fix it, and I’m ready to try out the next image/update when it drops!
