Can't get to the GRUB menu when booting my A04 devterm. Is there even a GRUB menu?
It’s been about a year since I booted my devterm, and I’ve apparently forgotten whatever clever password I set. So, I’ve been trying to figure out how to reset the root password. Unfortunately I don’t remember what version of the OS it’s running.
Help a brother out?
reset by editing /etc/shadow on microsd card. there is no grub.
@pkr , thanks for the fast reply! That’s great info, and I’ll give it a try and report back. :sign_of_the_horns:
Okay, I realized it would’ve been more helpful if I had set up my context in the initial post.
  • My main computer is a Mac running the latest OS, which wouldn’t read the sd card, I’m guessing because it’s a Linux file system. Same thing when I tried it with a Windows box.
  • I then tried to see if I could access the sd card on the Max through the terminal somehow, but couldn’t get that to work, either.
So, I’m stalled out again. I mean, I don’t have anything I’d miss on the devterm, and not opposed to reflashing the system. I’d just prefer to not do that if possible. Plus it’d be a good learning experience to get into the file system and edit some stuff. :smile:
Thanks in advance,
Aa.
You should be able to access the SD on a Mac, I don’t have any but it should read it.
You can always just use a live Linux distro to look at your SD card.
Yeah, I thought so too, but I’m obviously missing something.
The relevant partition on the card is most likely ext4/ext3, so the simplest way would be to mount it from a Linux system.
That makes sense to me, though I unfortunately don’t currently have another machine with a Linux system. Which is making me think I should probably just reformat the sd card and flash the newest image.
Though there must be a way to start up my Mac at the command line, and get into the sd from there…
you can run ubuntu live in virtual box and mount sd card there
seems possible: How to access an SD card from a virtual machine? - Super User
or…
you can get another sd card, flash there a fresh system and then modify old one via some usb card reader
devterm is a linux machine after all :slight_smile:
Hah! That would be pleasingly recursive! :sign_of_the_horns:
I’m gonna try the virtual machine first. That had crossed my mind, but when I googled around, I wasn’t grokking it.
And I may as well implement the second suggestion, too. Why not? :slight_smile:
I’ll report back, and thanks to everyone who’s offered their time and expertise to a seminoob!
Aa.
