Hello All,
I am developing a series of videos on ClockworkOS for my youtube channel and they will be freely available for everyone.
I have a few queries and I will need your help.
Is there any website where I can find reference for commands of the ClockworkOS?
I guess it is debian derivative like Raspberry Pi OS. Does it have any special Devterm A06 specific commands (sudo rpi-update, vcgencmd measure_temp, etc)
How to update the firmware with a command (rpi-update)?
Thanks a lot in advance. I will upload detailed videos on these things.
Itâs armbian-config; but I would advise against touching it - updating stuff through it can kill some parts of the OS, including WiFi and sometimes USB, and the only way to recover from it is to reflash the SD card.
ClockworkOS do not exist. The only thing remotely close to be called âClockwork OSâ is the front end you can find on the GameShell.
DevTerm are just plainly normal Debian based linux distribution with just a couple of sparkled tools/drivers specific for the DevTerm, other than that, it is just linux with nothing special.
There is no specific âupdate commandâ other than the standard Debianâs apt command.
So, the ARMBIAN build for Devterm-A06 includes some patches for things like the specific power management unit, display, wifi module used. Every single patch to Armbian is here: DevTerm/Code at main ¡ clockworkpi/DevTerm ¡ GitHub. There are no new contributions - like brand new drivers - just tweaks to armbians codebase.
There are no special commands, no /boot/config.txt files to alter. As was mentioned earlier - even the âarmbian-configâ command - related to âraspi-configâ is NOT USED.
The only specific commands to Devterm-A06 is the âdevterm-a06-gearboxâ command. This sets what cores are active and what speed they are running.
I deeply respect youtube content creators, but if you are looking for clicks - this is a very small community. If you are looking to be the expert in Devterm instructional videos, then youâll probably need to get into the armbian build process to be useful, or building support into some other arm64 supported OS. The videos out there show the very beautiful design of this Devterm, and the fun that comes from assembly. But the actual use of it is very much a hobbyist endeavor. Itâs just a portable raspberry pi.
For me, the pleasure in it was getting an old emulator for the Radio Shack TRS-80 Model 100 working on the Devterm. Honestly, most of the work on that was while SSHâd/VNCâd in to it from my laptop. Then I moved on to custom keyboard code in Arduino, developing it on my laptop. Now Iâm messing with building the OS image. Once again, on my laptop. All things Iâm truly enjoying. And would make a horrible youtube video. ÂŻ\(ă)/ÂŻ
Thanks a lot for sharing the information with me. I could see that there are 5 different distributions. I guess Clockwork OS is only for GameShell and DevTerm A06 is specialized for A06 model. Will Clockwork OS work on A06? Has anyone tried it?
