Hello! This sounds very similar to this problem:
So I’ve had my Gameshell around for a while, and it never really showed any problems until recently, when I couldn’t turn it on anymore.
So as of what I did before and afterwards:
I turned on my Gameshell the other day to play a game. Tried browsing through the warehouse to check out something new.
Noticed that my WiFi wasn’t functioning properly, regardless of setting the airplane mode on and off
Turned off the Gameshell and left it be. At this point, I knew that the battery was still pretty…
See if that works!
The fact that the light is on is a good sign at least. It means your SD card at least is correctly flashed. AFAIK, the light won’t come on unless there is a functional SD card present.
Try holding the power button for about 20 seconds as well. No idea how or why there would be such an absurdly long hold time, but hey! It’s worked for me.
Btw, is this related to your previous post?
ok so i tried updating the os to v0.5 and failed miserably and ended up accidentally deleting the clockwork pie OS all together, i keep trying to download v0.4 to a SD card but nothing is working. every time i try to flash it it fails. if i buy a new development board will it come with a new micro SD with the OS? or is there a way to save my clockwork pi without buying a new development board. im a begninner with tech but i guess messing up is a part of the learning experience. if anyone has any…
