YoonDM
                    September 4, 2021,  8:45am
                  1
              Hi,
I have a DevTerm with CM3.
And I installed two 3.6V 3500mAh 18650 batteries. (≒ total 25.2 Wh)
But ‘upower --dump’ command shows the below messages.
Why the ‘energy-full’ is 8 Wh but not 25.2 Wh?
Or have I fake batteries?
              can you share info on the batteries? brand + link to website you ordered from?
                YoonDM
                    September 4, 2021,  8:48am
                  3
              I bought KDsafe 18650 3500mah battery from South Korea.
              from what i can tell these should be okay but i’m not a native speaker/from SK so i cant say for sure, i would recommend you get a pair from a brand likr LG or sony or samsung, and test to see what results you get with those. it may just be a software issue, but testing with different cells can help figure out if its the batteries themselves or not.
                Godzil
                    September 4, 2021, 10:36am
                  5
              Discharge and charge using the DevTerm, that should “fix” this info. Currently it knows nothing about the battery
                YoonDM
                    September 5, 2021, 10:32am
                  7
              I replaced it with new batteries and got the same result. (Samsung SDI INR18650-35E cell with protection circuit)
Should I change something or remove the protection circuit?
                Godzil
                    September 5, 2021, 11:26am
                  8
              It is not the batteries. The chip have no way to know the battery information.
You need to do a couple of cycles of charge/discharge with the battery for the chip to know about the battery!
