I just received my uConsole and finished assembly of it using a 16GB lite CM5 board. I also installed the HackerGadgets AIO board.
I have a 256GB High Endurance MicroSD that I flashed the build of Parrot Security to. It does not boot, only briefly once flashing some text and then nothing else.
I am assuming I need to use another Linux host to modify the image? Or, are there pre-built CM5 images available and I just overlooked them?
Just looking for specific guidance as to what my next steps should be, in detail. Thank you!
I have a dozen images here on the forum that are pre-build to run on the CM5 in the uConsole. You’ll first need to follow the instructions in this post to get your CM5 fully working with the device.
