CM5 lite trixie nvme boot
Thank you!
To be honest I am still learning and have some issue. Like it seems to drain battery even if I use shutdown (known of the CM5 issue with the shutdown).
Might need to soder in a switch.
Other than that its been hard to know what NVME drives works good as some seem to lag.
and ofcourse, I need to troubleshoot not hearing anything with SDR++ Brown while Youtube works flawless.
but its darn fun to finally tinker with it
:smiley:
for audio in SDR++ brown make sure to read this section o SDR++ brown
Haha, Thank you! I have skimmed through that post and many others in my quest to learn about this device. But I did re-read it and found the solution so again, thanks!
And @Rex, I have noticed you are the creator of allot of these packages, images and even guides/instructions. Amazing dedication and thank you for your hard work :star_struck:
oh yea, good idea. Will get to that!
I have also the same problem. My screen is completely black when I try to power it up with only the ssd. I’ve tried almost everything for over 4 hours and completely gave up. I’d appreciate if anyone kind enough would like to help me. I’m a complete noob. :saluting_face:
