Does anyone have any ideas for database managers that will work on the uConsole?
uSQL and DBeaver both work on my devterm. Will work on uconsole.
I use MariaDB - is that what you mean? it installed without issue on the DevTerm - I build the Database in MYSQL workbench… (windows) - sigh…
DBeaver is perfect and does what I need. I recently transitioned over to JetBrains DataSpell/DataGrip to manage my PostgreSQL data server. @MHam68HC11, I am looking for a front-end solution to manage the actual database itself. I can manage from the command line, I have a use case where I need to upload batch CSV files on occasion and DBeaver can do the trick when it might be a one-off case. I like DataGrip because it can set up the table for you from a massive CSV file based on the data. Honestly, there have been very few cases, where I have had to manually adjust the data types for each column.
As much as I love writing SQL code, DataGrip has been a huge time saver, definitely worth the subscription.
Okay that’s what I was missing - yes the build part is a pain! I use MYSQL workbench - built my databases - data entry still working that - believe it or not NodeRed can be configured to take entries in a webpage and input lines of data into a database… For display of the content I’m looking at Grafana… but up front I had to visualize my application - the design part (conceptualization) is the secrete sauce … the rest is nuts and bolts…
Download | DBeaver Community there is a debian install package… I’m just starting to raise my linux skill to install from package before I always had to use apt-get install…
I’ve been using Python scripts activated by cron jobs to grab news headlines and Reddit posts based on specific keywords. It’s been working well, but power outages can be a real pain sometimes. I have been using the nltk library to extract sentiment scores from headline titles, as well as Reddit post titles and post bodies. I used this to extract the correlation between S&P 500 vs. News Sentiment, and S&P 500 vs. Social Media sentiment. I have been collecting the data since 2021. I wish I started doing this pre-COVID, to have a snapshot of everything prior would have been extremely valuable.
Grafana as an EXCELLENT visualization tool. Recently, I discovered Apache Superset, which is pretty neat too! One feature I like about Superset is the ability to save SQL queries and charts separately from the main dashboards. I found it a couple of weeks ago and thought it worth sharing with the community!
For those stumbling upon the discussion, here are the solutions being discussed up to this point:
- MariaDB: https://mariadb.org/
- PostgreSQL: https://www.postgresql.org/
- DBeaver Community: Download | DBeaver Community
- JetBrains: https://www.jetbrains.com/
- Grafana: https://grafana.com/
- NodeRed: https://nodered.org/
- Apache SuperSet: https://superset.apache.org/
- Software and Solutions from the Apache Foundation: Apache Projects List
You have a good point, MySQL and PostgreSQL do have local browser-based GUI DB managers.
