Hi will a devterm cpi work in a uconsole and clockwork accidentally gave me a devterm cpi in my kit and make an os that works for a uconsole cm4 108000 with devterm cp.
Thank you.
Thank you.
Not exactly sure i understand the issue, but If you you suspect you got the wrong part, i would suggest contacting Clockwork directly. They should be able to get it working, or send a replacement.
The DevTerm and uConsole use the same main board and CM adapter.
You can find compatible OS images here in the forum.
But do you have to comment the uconsole stuff out and uncomment the devterm lines
Do you make images for devterm
If you don’t make a bookworm image with the original raspbian boot screen and no dark mode and no clockwork pi setup logo.
All my images work for both the DevTerm and uConsole. You only need to change the config.txt if you have a DevTerm.
No I do not make a stock RPi bookworm image. You can turn off dark mode and put whatever image you want as a splash screen.
You can even disable the splash screen and just get the console output.
main board is same
