Hi guys, can someone explain the main differences between the two launchers and which launcher is better to use. Thank you in advance
But is there a reason that the gameshell comes with both?
As LauncherGo is still in it’s infancy, it comes preinstalled so that you may test it, if you so desire. If you find issues with it please post them on this forum so that LauncherGo may advance further in it’s development.
at the beginning, we just want a faster “launcher”
but because the lack of development group for two launchers (in fact just one person only )
so the progress of LauncherGo is always behind launcher
the biggest difference is the Speed ,nothing more
Looking at the GitHub repos for both, Launcher is up to date and getting updates regularly, while LauncherGo hasn’t been updated in quite a while.
Is it OK to remove LauncherGo to recover a bit of storage space? What do I need to remove other than the ~/launchergo directory to get rid of it cleanly?
if you removed the
just try not to click the switch to launchego in the future,or you will have no launcher at all because the launchergo is gone
and if you happend to enter this situation
ssh into gs
edit ~/.bashrc in the bottom
replace the
if [ -f ~/launchergo/.cpirc ]; then
. ~/launchergo/.cpirc
fi
to
if [ -f ~/launcher/.cpirc ]; then
. ~/launcher/.cpirc
fi
that will have launcher back
It would be nice to put an else to fallback to launcher i there is no launchergo path
yeah , you are right
I also thinking about to hide the launcerGo forever since few people are using it and the develoment is way behind the launcher
Mmm. The poll I ran a couple of months ago was looking that way. But I’m guessing if it does get updated, people would use it?
