Display Problem on uConsole: Garbled Screen on Two Different OS Images, But Shuts Down Properly
My uConsole is flashed with ClockworkPi-RetroPie-6.12.25.img and uConsole-ubuntu-22.04.5-preinstalled-desktop-arm64+raspi. However, after inserting the SD card, both systems cause the uConsole to show a garbled screen on boot and fail to start. Pressing the power button shuts it down normally, so it’s not frozen. It seems like a display issue. Does anyone know how to fix this or has encountered the same problem?
If you just received your device you have the newest screen. So you’ll need the most updated images. The retropie you’re referring to won’t work you’ll need a newer version. The Ubuntu version won’t work at all with the device, as the device needs special drivers in the colonel to operate correctly.
Start with this image here to make sure the device works correctly.
The other images in the same Google drive Link will work with your device also.
