Do I need a better cellular antenna?
So I have my uconsole not yet and I ask my if I also need a antenna for cellular. I now that it’s better for Wi-Fi but I didn’t find it cellular a better antenna needed.
If you ordered version with 4G extension, cellular antenna should be included. And as i tested, it works quite well.
The only possible issue is that if you stick it to the metal part of uConsole, you might get poor signal. If you run into this, just stick it on non-conductive material, and that material - to uConsole (tested on my wifi antenna)
Also I planned to replace the Wi-Fi antenna and I don’t know if the antenna block the LTE module?
Here are some links.
I haven’t used custom antennas with uConsole yet, but i know that they won’t block LTE signal. If you were asking about physically blocking, i don’t think this would happen - that mount would still aloow you to stick LTE antenna nearby
