The build instructions for the R01 refer to devterm-fan-control-rpi package, but that contains a script that relies on the existence of the Raspberry Pi-specific /opt/vc/bin/vcgencmd command to read the temperature, and that does not exist.
What’s a good way to monitor temperature on the R01?
This doesn’t answer your question, but from my testing with other Allwinner D1-based devices it’ll never get anywhere close to a temperature where you’d need to turn the fan on.
Had a look at my benchmarks for the Sipeed Nezha D1: 1.1W under full sustained load. That’s for the entire board, with HDMI display connected.
I’m not complaining about not needing the fan
just wanting to see what the hardware / software options are here. Probably worth documenting somewhere on the wiki, that it should not be expected or needed.
For now, I’ve made an i3-block that displays the following
TEMP=$((cat /sys/class/thermal/thermal_zone0/temp / 1000))
This seems to work well enough!
Following up on my own thread here - specific to the R01.
The GitHub wiki page on building for the R01 refers to installing the devterm-fan-temp-daemon-rpi package. This is pointless, as the code will not work at all. I recommended removing that from the build.
I created a couple of shell functions for myself (note that I switched myself to zsh from bash, so these might need to be modified) to check temperature, and to switch fan on and off if needed, which is unlikely.
function temp() {
(( temp = $((`cat /sys/class/thermal/thermal_zone0/temp` / 1000)) ))
echo $temp C
function fanon() {
gpio mode 41 out
gpio write 41 1
function fanoff() {
gpio mode 41 out
gpio write 41 0
I’m still looking into a good way to enable user access to gpio, as mentioned here.
