I’ve received DevTerm A06 yesterday.
Assembly
Assembling it was super easy and fun. It reminded me of plastic models from my childhood. The assembly guide was also helpful. It almost didn’t require any tools to assemble it (except a small Phillips screw driver). The quality of injection runners were so good so I didn’t have to trim them even when I’ve torn them off with my hand. Overall build quality was good.
I’ve glued side IO panels not to lose them.
This threads helped me a lot solving some mysteries and hard parts (a display assembly, a heat sink, a kapton tape, etc…)
And then it booted successfully in the first time. I played well with it for few hours :).
Supplies
I bought a pair of button-topped, protected 3500mAh cells.
But I think flat-top would’ve been better. It’s a little bit hard to put them in.
The estimated battery time is more than 5-6 hours. I’m very impressed.
Also I bought 57mm x 40 mm (width, diameter) thermal paper. It was a hard bet.
Some problems
It seems that the trackball misses signals when I move it fast. And also the middle mouse button doesn’t work as a mouse wheel unlike the TrackPoint. This is why I’m going to try Godzil’s keyboard firmware and even considering my own fork.
The screen doesn’t turn on after waking up from sudo systemctl suspend. SSH session works though.
Speakers are great. Its quality is surprisingly good given the small and closed enclosure. However, I can hear statics with a USB-C charger (which is not well-grounded) is plugged in.
I can connect a bluetooth keyboard, but it is done with bluetoothctl. Bundled GUI couldn’t handle my keyboard’s pairing process.
Also it froze 4-5 times while playing around with it. I thought it was the keyboard connectivity problem since it uses POGO pin. However it wasn’t. The keyboard can actually be hot swapped, and the system actually went unresponsive. I might try to rewrite the SD card first.
The thermal printer is somewhat flaky.
The feed motor slips a lot. It might be due to the misaligned thermal paper, but it is very sensitive to it.
Also it is somewhat weak than I’ve expected, and prints a lot of streaks.
I might have a faulty module.
The clip at the top doesn’t close well when the extension port cover is opened.
edit: My batteries seem to be slightly oversized.
Although these problems, I love this machine. I’m going to have a good end of the year with this. Thanks.
