check section folder, it got some example lauch files, you could also create categories & links from the app
I see that. It wonât let me search through the navigator for any files to link. Iâm just not sure how to create a link. I donât know what goes into the text file
there is a âshow rootâ option to start from /
I saw that as well. However it just turns off automatically
sorry no much time to check and my unit is not here,
wasnât there a command and a param entry in the file ?
just put your classic sh file path as the command must be ok
itâs turn off ? entering sleep mode ?
i was made some test to compile & configure dingux fork, but not tryed made it launch anything
donât have done some other test on this original gp2x version too âŚ
i will try next week
Sorry I should have been more specific lol. âIt turns offâ I meant the option for root.
When I turn it ON in the settings, and leave settings it turns OFF so I canât search through my SD card.
No Param for it by default and I dunno what to add. Thanks for the help man
you mean the option turn back after your restart gmenu2x ? or if you reenter the option menu ?
check you quit the config windows with an ok action and not a cancel one
also gmenu2x must save his config when it exit, you could done a âpkill gmenuâ from command line to send him a close signal
i was also got save problem in my test, but as i was on an open unit i done some thing by ssh & mouse pluged
the file browser must request the command entry, so the file to execute
try adding one of the sh file inside menu folder that you use with the clockwork launcher
It instantly turns off when I leave the menu. Iâve tried every button Iâll try again!
you may miss a button to configure ?
Iâm using the GameShell config it came with. Maybe I will try a re install. Can you copy paste your input config?
i must check, also i configured the dingux fork, not the gp2x
