This is a UI that can replace the official launcher
Looks nice !
This is the same UI as the Bittboy PocketGo, right ?
Can we configure the language to english ?
Yes, you can do this
I made it and it runs fine.
Any Idea on how I could launch it on boot ?
edit file like this
/home/cpi/launcher/load.sh
Thank you! I thought of doing that.
But I was wondering if there was not a more “clean” way. Instead of launching load.sh, launch the Gmenu2x directly… ?
But at least it works. On the other hand I would like to understand how to create a shortcut to launch a program, like emulationstation and SorRemake for example.
I think I had to create some folders in “sections” first, “applications” and “games”. Then add some files for es and SorR, but what do you have to write inside excatly?
you can also edit this file to modify the launch configuration.
/home/cpi/.xinitrc
sections configuration can refer to here
Thank you !
But edit /home/cpi/.xinitrc doesn’t change anything
How do I install this?
Hi,
It’s too late now but I’ll explain tomorow
to compile :
make touch README.rst make dist
you will found a dist folder, where all necessery will be found
create a .sh who cd to that folder and run ./gmenu2x
What’s the script for the .sh?
I’m not good with that stuff I tried to make one but it just boots back to the normal launcher lol
maybe your sh wasn’t executable ? try chmod +x on it
you could also put shebang at his top #! /bin/bash
assuming you renamed dist folder to /home/cpi/games/gmenu2x :
#! /bin/bash
cd /home/cpi/games/gmenu2x
./gmenu2x
chmod +x *your sh file*
Only thing I didn’t put was the top line lol thank you!!
hey brotha how did you configure the controls?
it’s in the input.conf file, with keyboard key values
alright cool but how do I figure out the key value? I thought it was somewhere in this forum I just cant find it.
It’s here (I use Google to search for stuff on this forum, the search here is kinda bad):
you could start with existing conf file
key is sdl 1.2 ones, check values here https://github.com/svn2github/fb_ray_tracer/blob/master/branches/dev/SDL-1.2.15/include/SDL_keysym.h
epic man got it workin. currently googling how to set up emus and roms. any info would be appreciated
