? And there I thought I did just that 2 messages up :wink:
But anyhow, more people have chimed in already so everything is fine.
#5172 shipped. After the courier agent uploads the tracking number to our webshop, you will receive a notification email.
They used the same pin order, so it should work, just be aware the first pin(5v) positon.
Problem solved. I’ve sent 400+ packages to the freight forwarder before the New Year. They already sent 70+ out, and the rest were held due to the holiday. They will send the rest out around the 5th. And the rest of the unshipped orders(non-Radxa version) will be fulfilled before the 10th, after I return from my vacation.
Hello Vileer,
Best wishes for 2026!
Thank you for your reply. I only received an SMS from FedEx, but it does include a tracking number, so that’s fine—I’m able to follow the shipment.
Regarding the upgrade kit (previous order), just to be sure: what type of NVMe PCIe M-key SSD should be used with the NVMe + battery board included in the upgrade kit?
I’m mainly wondering about Gen 3 / Gen 4 / Gen 5 compatibility, just to be sure it will work properly.
Thank you very much in advance, and have a great day.
Gen4/Gen5 SSD was downcompatible. But they usally required more power. So the Gen3 may be the fist option.
Noted, thank you for your quick reply!
I know this question has had to be asked somewhere but I cant find anything.
Is it possible to have a main image on the SSD but have the option to throw something else on an SD and boot from there? I didnt think this was possible and since I want to use 3 total distros, I didnt think I could use the SSD on the HG board.
to whomever it may concern…..
after 6"+ hours (over a couple of days) trying to get my Western Digital (PC SN810 NVMe WDC 512GB) nvme to work, I decided to try another nvme drive I had. a small 2230 factor Hynix nvme. Plugged it in my mac, used pi imager, flashed one of REX’s images. and it booted straight away.
So…..
not all nvme’s are created equal. the wd drive, being a gen4, may have a bootloader incompatibility or some other issue, that prevents the system to boot from that drive. Whenever it tries to boot from it, I get the 5 ACT led flashes on the nvme board. This is a pattern that means it can’t find the corect boot files / incorect bootloader / Unrecognized NVMe Drive / etc….
if you have this issue (imposible to boot from nvme), try with a diferent one.
Couldn’t you just partition your m.2 (use a bigger one) and use GRB boot manager to select which to start at boot time?
I have Ubuntu on a 1TB SD card, and Trixie on a 2TB NVMe. If the SD card is in place, the uConsole boots Ubuntu. If I remove the SD card, Trixie boots. Is this something like you’re looking for? I don’t see how to boot three operating systems, though.
Thanks for the insight. 2 images would be doable for me so I may go that route.
I was initially planning on using the 5th connector on the aio v2 board for the ac 1200 wifi dongle and using the old antenna quick connect board for gps/lora/sdr/onboard wifi. I’m relatively unfamiliar with the specifics of radio, if I leave the 3 of the connectors on the ac1200 dongle empty, would that risk damage to them?
While waiting for the upgrade kit, I would like to ask about compatible and/or recommended NVMe SSDs. Are there any known limitations? I noticed in one of the posts that PCIe Gen 3 SSDs are preferred—could you please confirm this? What SSDs are you currently using that work without issues? Thank you.
This is the way mine is set up also. Works really well!
Do not run it without antennas plugged up, you can damage it.
Camera: For those trying to use the CS1 camera connector, I have found a working configuration:
  • CM4: I was /not/ able to get this to work, after quite a bit of effort. Not clear what the issue is.
  • CM5: Just the normal way: add dtoverlay=imx219,cam0 (or the appropriate sensor for your board) to /boot/firmware/config.txt
I wasn’t able to get a WD gen4 (PC SN810 NVMe WDC 512GB) drive to work. after 6+ hours I gave up.
Installed a gen3 Hynix (BC511 NVMe SK hynix 256GB) nvme, and got it running in 2min.
my two cents…
I am having a issue with my RJ45/USB expansion board. When I boot from SD card with the expansion board in the power button blink fast once and then nothing. If I remove the expansion board everything boots fine. Running the full Upgrade kit and a CM5 lite. Sent an email to hackergadgets but haven’t heard back. Order #6213.
Vileer is on her sometimes, but you are better off emailing them through official channels. They respond quickly and can help you.
