Has anyone had luck with 70mm long batteries and/or 18.6+ wide batteries?
Found good 18.3mm x 70.0mm 18650 batteries, will they fit?
Molicel M35A
Protected Button Top, 3500mAh, 10A.
But the dimensions are off from recommended
(18.3mm x 70.0mm vs Ø18±0.5mm x 65-69mm).
Has anyone had luck with 70mm long batteries and/or 18.6+ wide batteries, thanks.
For anyone still interested, yes, they do fit :slight_smile:
Works well. 8h of battery life at 100% CPU on R-01.
Perfect for Emacs and Terminal stuff, both come preinstalled.
I’m using the flat top with excellent performance. Yes they do work.
