I flashed the official 0.2 CM4 image and everything was working fine. However, the system soon after performed a kernel update, after which, I couldn’t use the machine any more.
I have reflashed the 0.2 CM4 image five or six times and every time it breaks with a kernel update.
I assume the new kernel just doesn’t contain the display driver or whatever.
So can I either
A. have the Kernel update and still retain a working device?
B. block the system from every updating the kernel?
NOTE: Your kernel might not say ‘linux-kernel’ or anything similar and may look like a random splash of nonsense numbers. Here is an example from one of my Fedora boxes
Step 3: Hold the kernel packages in APT
Run the following command, but use your kernel version from above: sudo apt-mark hold 5.4.10-generic
Apt will spit out a list of packages that are “set on hold”
Pretend Example Output:
[User@Machine ~]$ sudo apt-mark hold 5.4.10-generic
linux-headers-5.4.10-generic set on hold.
linux-kernel-5.4.10-generic set on hold.
linux-kernel-5.4.10-whatever set on hold.
There will be several packages held.
Other commands you should know if you need to undo these changes:
Show held packages apt-mark showhold
Unhold a single package: apt-mark unhold package_name
Unhold all held packages using some fancy command substitution: apt-mark unhold $(apt-mark showhold)
